problem photocopying with scanner
I have a problem with my scanner a primax Colorado direct 9600.
After having to reinstall windows 98 I lost all my programs.
I have found a driver for the scanner and the scanner is working, but I can not now use it as a photo-copier, which I could before.
Has anyone any suggestions?
1 REPLY
See if any of these freebies do the trick:
http://graphicssoft.about.com/od/scanningsoftware/
http://www.brothersoft.com/Utilities_Fax_Copy_and_Fax_Utility_9924.html
You probably do need a TWAIN driver which may already be installed with the scanners drivers you have now.
I can't find a copy of the original install CD on the net, primax require £7.50 to get a replacement. I assume you have lost this?
