plus net plus
plus net plus
have read below when downloading the rate drops but how much saying 10meg download is it like dial up 5k or higher say 30k just asking as i might have to sign up to the premier package as i download some files .
guest.
LiamM
plus net plus
Might be worth trying Plus first to see if it is for you. After all, it is then free to upgrade to Premier if you feel you need it.
plus net plus
The speed reduction cannot be quantified as it will change depending on how busy the network is.
