connection problems
connection problems
hi im dave my friends just gone on broadband unfortunately with pipex
but anyway you good people im sure will help we tried to install modem alcatel 330 but the two green would not stay on there was a noise then the adsl light started flashing we tried to uninstall and do it again but it still did not work any help appreciated thanks dave neil soon to be plusnet
1 REPLY
connection problems
Hi Dave,
The noise bit sounds kinda strange. Was the noise from the PC or the router?
Any how. This tutorial should point you in the right direction
http://portal.plus.net/central/forums/viewtopic.php?t=9565
If you follow that and are still having probs post again and I'm sure you'll get all the help you need.
Best regards
Mark
