add BT number for dial up?
hi
going away tomorrow for a week, i saw somewhere saying i can add BT phone number to dial from. primary one is my home number but i cant find anywhere i could add other one to dial out?
or will it work if i use dial up from anywhere in the UK?
thanks
wesley
Fixes: 57
EDIT - I didn't mean to post this
You should just be able to use 0845 1400101 from any UK line as a dial up number.
holdtight
Hi Wesley
Do you want to dial up using your plusnet account from another property using there phone line ?
If so what you need to do is add that properties telephone number Here but dont set it to primary that needs to stay at your home address
Once done you can dial up from there just as you would at home but dont forget the charges go to there phone bill and not yours
Bill.
