What is the prefix code to call a PlusTalk subscriber ?
What is the prefix code to call a PlusTalk subscriber from another sip network such as Gossiptel ?
Welcome to the forums.
PlusNets SIP ID is **768
Hope that helps.
Hi Mark,
A prompt reply, much appreciated and indeed helpful thank you sir.
With regards,
Bob Cheesy
Don't seem able to dial my TalkPlus number from FWD using the prefix **768 .
I regularily access Gossiptel numbers from FWD using their prefix **467 )
Can successfully dial FWD numbers from PlusTalk using prefix ****393.
PlusTalk is currently working on X-Lite softphone running on W2k Pro.
Have FWD working on Pulver's soft phone and on Sipura SPA3000, but not on both at the same time.
Is this finger trouble here or might there be a problem calling to PlusTalk from FWD ?
Kind regards,
Bob
As far as I understand it, PlusNet have to peer with other SIP providers before you can call them "directly", so to speak, using the prefix. I do not see a peering entry on this list for FWD.
Thank you for the link to the peering post which I stumbled accross just after Mark's reply - FWD is on the list.
The post ends :-
""For friends using these peers who want to call you,
our (PlusTalk) SIP ID is **768 ""
I cannot call my Plustalk number (eg. 123456) from FWD on another pc by dialling **768123456.
On that other pc using FWD I can successfully call Gossiptel numbers.
Regards, Bob
LiamM
FWD = Free World Dialup
