Web-based FTP
Web-based FTP
Hey,
Is there any way I can delete files on my cgi webspace via. ie without using ftp:// such as a java applet?
1 REPLY
jberry
Web-based FTP
You can use telnet or ssh to do this if you want. There is a tutorial on using this here. Once you are connected then you will need to use the command rm .. like this
agiantpeach@cgi01 agiantpeach $ rm filename
or
agiantpeach@cgi01 agiantpeach $ rm -r directory
Note that you only type the "rm .. " bit.
Regards,
