Size of text on Plusnet site
When viewing the Plusnet site, some of the text on the page is rather small and blurry and difficult to read. The main body of text is fine, it appears to be additonal information that is in boxes which is the problem. This is the only site where I have come across this problem and as I don't have much technical knowledge, I'm sure it must be very simple to remedy.
Any assistance on this would be appreciated as I'm about to sign up to Plusnet but this is making reading some of the information a little difficult.
Thanks.
Lizzy
What settings have you got under "View > Text size" at the top of your screen.
You can adjust the size of text here.
Also can you give an example of just where its blurred as this is not happening when I view the pages. (view set to medium)
Shockedops:
That simple! I never even knew I could do that! Text size was set to smallest, I've now changed it and everything is fine.
Thank you.
Lizzy
No problem, Glad it was just something simple.
Enjoy your new highly visible surfing Cheesy
