Regrade Question
Regrade Question
HI Guys,
Today by BT Switch is being upgraded as part of BTs endevours to upgrade all switches.
So today I should be able to surf on the maximum line speed allowed. However, once BT do what they need to do, do Plusnet need to do anything?
Or will it dynamically change?
Steve
Alecto
Regrade Question
You didn't read May 05 as May the 5th did you, instead of May 2005? Tongue
Either way, it should all happen without your intervention.
But if you do find your line syncing at 2Mb but the speed test showing half or 1Mb, then it's because Pn haven't updated things at their end and they will need a ticket or phone call asking them to unthrottle your line.
Regrade Question
Ah ha! Very good question, I'll double check that one. Wink
It's good to know that little intervention is required at my end.
