Plustalk rate to 0845/0870 numbers?
Hi just want to find out the plustalk rate calling to 0845 and 0870 numbers. If possible pls compare with the BT standard rate.
http://www.plus.net/residential/voice/plustalk.shtml?link=res_plustalklink - the tarrif page.
The BT costs you should be able to find out from the BT website. because it depends on what calling plan you are on as to what the costs are.
thanks
however according to BT website, the 0845 is charged at 3p/1p/1p Daytime/Evening/Weekend. The plustalk seems to be much expensive.
Link
[Moderator's note by Liam (martinfamily): Truncated long link as it was stretching the page width]
