PlusNet speed test
PlusNet speed test
Can anyone tell me the port used for the speed test. I'm getting a speed of 0.0 now that I've secured my router, so I'm guessing it's a blocked port issue.
Cheers.
PlusNet speed test
Does your router filter Javascript?
This may be the cause.
PlusNet speed test
It's not a blocked port issue and it uses the standard port 80 (or 443 is usng an https connection).
The speed test i sknown to report 0 speeds and is often cause by your firewall. Try the test with the firewall disabled, try tt with a http instead of an https URL and if neither work, just wait until tomorrow and it probably will work.
N alternate speed test you can try is ADSLguide speed test.
