No e-mail or Webmail
Don't know if anyone else is having this problem but I can't pick up e-mails or access webmail. I keep getting an invalid username/password, however I know the details are correct.
I can log in and use dial up but can't access any e-mails.
Does anyone know of any problems?
Check the Service Status. This is the subject of lots of reports.
server status
How do you check the server status. My e-mail won't work on POP3 or webmail.
sam
I have just checked your webmail and I have been able to sucessfully login.
Please make sure that you are not using the email address as the login, the username / password should be the same as you used to access the member centre.
With regards service status, there are no current problems with email but for future referance they can be found here http://portal.f9.net.uk/supportpages.html?a=2
If you are still having problems it may be worth checking your settings, help with email can be found here http://portal.f9.net.uk/support/email/setup/email_setup_guide.shtml
If none of the above resolves your issue then please raise our support team a question via the support wizard.
