More than one computer, can they both get Broadband?
Currently getting Broadband at home and would like to use a 2nd computer, is this possible?
Yes you can either get a router (best method) or set up internet sharing.
Both PCs will need to have network cards fitted though but these can be had for about £10 and most modern PCs come with them in anyway.
And possibly a hub/switch?
Although if the router has more than one ethernet port on it you wont need to
Yes I was meaning something like a 4 port router, either Dlink or Netgear for example which would avoid the need for a seperate hub.
ah, my router is obviously pants then, it only has a sinlge usb and ethernet out Smiley
