Connecting to net
Connecting to net
It states on the hardware installation tutorial "Enter your username into the dialler box, e.g. username@plusdsl.net. Now enter your password. Press 'Connect' or 'Dial' to complete the connection"
Is this something you would have to do everytime you switch your pc on to connect to the net or only on the initial installation?
Thanks.
csogilvie
Connecting to net
If you are using a DSL Modem through a Windows Connection, you should be able to tick "Remeber Password" and configure the connection to start automatically. However, its been ages since I did it, so I can't remember specifics.
Plusnet Staff
Plusnet Staff
Connecting to net
Easiest way is to either tick the connect automtically tick box, and create a shortcut to the connectoid in your Start Up group in the start menu.
