Connect to PlusNet using GPRS?
Does anyone know how to connect to PlusNet using GPRS over O2?
Walpole
GPRS is a mobile operator dependant service, and doesn't use third-party ISPs like dialup and DSL.
As such, you can only use GPRS to connect to O2.
I don't know how O2 works, but be careful to take note of what their gateways allow you acces to... for instance, there may be one gateway for WAP, then one for the rest of the internet.
Thomas
Dev
Don't know about O2 & GPRS, I'm on Virgin, I connect to PN via the dialup number and can downlaod and send mail from my phone with the pop3 access.
jberry
With O2, depending on your phone type, you can go to their website and it will text you the settings and set it up for you.
Regards,
