Clevedon
Clevedon
I live in Clevedon Nr Bristol I was reading somewhere that an isp has a main connection point near me. Was it plus.net or bulldog?
1 REPLY
LiamM
Clevedon
Plusnet is available on any BT enabled ADSL exchange in the country. Bulldog is limited to 'Unbundled' exchanges only - so you'd need to look at http://www.bulldogbroadband.com/support/broadband-across-London-and-the-UK.asp to see if your exchange is Bulldog unbundled.
Regardless of whether it is or not, Plusnet will be available on your BT line if you are connected to an ADSL enabled exchange, which I am sure you will be. And you won't be making a mistake signing up to PN either!
