Bandwidth usage measuring?
Is there some way that I can tell how much bandwidth I have used per month?
Not using a PC program as I will be using an Xbox mostly so need to know via plus-net servers etc?
I.e. does the "web stats" section of the member centre tell you this?
Thankyou.
Yes - click Connection settings (under My account on the left) -> View my usage.
This works for both broadband and dialup accounts except PAYGO I believe.
The webstats shows access to your webspace (website) not your ADSL line usage.
Thankyou, oh ever helpful Peter...
