when will they be able to get fibre ?
- Full Fibre
- Re: when will they be able to get fibre ?
15-09-2015 9:51 PM
So what can be done ? Can we contact anyone to see if fibre will ever come to this area ? I did once ask plusnet via support ticket and i think i was told nothing can be done, but surely there must be somthing or somone we can cantact in order to try get it here?
My parents are currently paying £9.99 a month for 1.5meg connection with is too slow, plus they have their phone with plusnet too. Because of the fact the internet is so slow it might be worth them looking for another provider as some providers do offer cheaper internet or even free internet with speeds that low.
15-09-2015 9:55 PM
They can get fibre when this resource says it is available - http://www.kitz.co.uk/adsl/btwchecker.htm
There is nothing you can do but wait, A cabinet does not need to be too far down the road before its useless for VDSL transmission.
15-09-2015 10:04 PM
15-09-2015 11:03 PM
15-09-2015 11:07 PM
BT will happily provide them with FTTP.
16-09-2015 10:03 AM
16-09-2015 12:09 PM
However I must stress that as FTTP is still only a trial, response times can be delayed and there are quite often delays on the orders with our suppliers.
16-09-2015 3:33 PM
16-09-2015 3:53 PM
17-09-2015 10:16 AM
Also why is there so much more fuss about getting this FTTP installed ? Why is it not as straight foward as a normal upgrade to fibre. I basicly want to try get them signed upto fibre 40/20 package but from reading all the info on it, its kinda putting me off.
And how long are fttp trials running for before fttp becomes the norm? and anyone can order it ?
17-09-2015 10:55 AM
Frankly you don't have much choice. FTTC and FTTP have significant connection differences. With FTTC the last leg of the connection is the same copper wire from the cabinet as you already have. With FTTP the fibre has to be brought right up to the property, so installation is more involved..
By the looks of the availability report BTw is not offering FTTC at that address, so you gave the option of staying on ADSL or moving to FTTP. Given the option, I'd go for it.
PlusNET can only offer what is available from BTw.
Hope that helps to clarify matters.
17-09-2015 10:59 AM
If you want a fully supported Retail packaged product then go to the BT Retail site as they sell FTTP as a normal product .
If you use the cash back websites then you may get a really good deal especially as you would be ordering "Infintity 1" FTTP (40/10) and that is the market segment were good deals can be had.
As to why is there more fuss about FTTP installs, well they are harder to do. Openreach have to run a fibre optic cable to the house and that is the problem area. If the cable goes underground then there is the real possibility that the cable ducts have become blocked and the engineers need to get that problem fixed. Or if, as in Cornwall, the fibre goes via poles, then there may be trees in the way which need to be pruned first or other obstacles to the clear path of the fibre. It is a real engineering job, on pare with installing a new line at a property which has no existing infrastructure. And finally, as it is a multiple person job and time consuming and a specialist job, it is harder for Openreach to schedule staff as it stops them working on other issues or means that they have to travel quite a distance from their normal area so get less hours in the day in which to work.
17-09-2015 11:14 AM
17-09-2015 11:19 AM
The last comment a few months ago from Plusnet, was that there were no plans to change the status of the trial one way or the other.
17-09-2015 11:33 AM
- Full Fibre
