trial so far
- Full Fibre
- Re: trial so far
- « Previous
- Next »
Re: trial so far
23-06-2012 8:21 AM
dick:quote
Re: trial so far
23-06-2012 9:48 AM
Re: trial so far
23-06-2012 10:03 AM
I'll try again later.
Re: trial so far
23-06-2012 11:19 AM
Done via ethernet connected to laptop.
Re: trial so far
23-06-2012 1:10 PM
have the other tests been via wi-fi then?
Even with 'top of the range' wi-fi the real achievable speeds are surprisingly low. NEVER believe claims of 150, 300 or 450mb/s for wi-fi equipment (even with no interference from neighbours or other equipment and your laptop sat nearer the router then the length of your shortest ethernet cable, with no obsticles etc.)!
My 300mb/s (5ghz band) wifi was only getting 20-25mb/s at 3m distance though a change to a setting on the laptop adapter did manage to increase this to around 50mb/s but still always less than ethernet.
Re: trial so far
25-06-2012 12:41 PM
Re: trial so far
25-06-2012 1:09 PM
'Better' wi-fi routers are certainly available but can still be limited by interference so, sorry, it's not possible to give you an answer that would guarantee a solution (other than connecting by ethernet!).
Maybe someone else can make a (more helpful) suggestion
Re: trial so far
25-06-2012 6:25 PM
Re: trial so far
25-06-2012 6:37 PM
Re: trial so far
26-06-2012 1:04 PM
- « Previous
- Next »
