trial so far
devil5882
trial so far
2 days in and ive seen huge improvement in upload but download not changing much does it take time?
39 REPLIES 39
sjmartin60
Re: trial so far
Your speeds are twice as good as mine down and 3 times better up Sad
willm888
Re: trial so far
Firstly, what does BT suggest you can receive
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Now check what your profile is here:
http://www.speedtester.bt.com/.  Use the FTTC diagnostics test and see what the IP profile for your line is.  The max download is something like 77500kbps and 20000upload (It would appear that your upload profile is already topped out though with speeds like that)
If not then it's likely that this is close to the max you can receive (although as it's only been on for a short time it may still be finding the stable connection speed)
If this is at the max then there's a few options:
Try rebooting the modem since some have reported this updates the download sync speed, alternatively look here as I had a very similar issue.
http://community.plus.net/forum/index.php/topic,104691.0.html
Any idea of the cable length from you to the cabinet?
I was told to wait 10 days but, tbh, found that, once I'd changed my router, my speeds were immediately up to the profile.  I do know, however, that my max rate is around 120mb down and 40up so was fairly certain it wasn't being affected by SNR.
devil5882
Re: trial so far
the checker said i can get 68.8 download 20 upload so i guess ill never get over 70 but atleast theres room for improvement
adamwalker
Fixes: 221
Re: trial so far
FYI I've already answered this question here: http://community.plus.net/forum/index.php/topic,102776.msg892278.html#msg892278
 Adam Walker
devil5882
Re: trial so far
yh sorry i did see it and replied.
devil5882
Re: trial so far
still no improvement on download speed there must be a problem somewhere.
adamwalker
Fixes: 221
Re: trial so far
The 10 day line stabilization period ends on the 21st so if this is still an issue after the weekend please get a fault raised and drop us another reply: https://portal.plus.net/apps/kbdfaults
 Adam Walker
devil5882
Re: trial so far
adamwalker
Fixes: 221
Re: trial so far
The faults team should be picking that up ASAP for you.
 Adam Walker
devil5882
Re: trial so far
ok ty
devil5882
Re: trial so far
just clocked one of my highest speeds so far.
w23
Fixes: 4
Re: trial so far
That's more like it, did the faults team do anything specific?
Call me 'w23'
devil5882
Re: trial so far
No we tried to test the modem but kept getting an error code i said i would see how it goes after all it is a trial so hopefully im helping.
adamwalker
Fixes: 221
Re: trial so far
You definitely are!
I'm glad to see that the speeds have picked up for you.
 Adam Walker
