incorrect username at install
- Full Fibre
- Re: incorrect username at install
02-04-2013 11:50 AM
Hi
is the FTTP trial using different accounts?
The engineer has just finished connecting the fibre but its not taking my username
I'm still on the f9 if that makes a difference
Message 1 of 3
(1,637 Views)
2 REPLIES 2
02-04-2013 12:26 PM
sorted!
the auto login on the fibre router didnt set itself up properly.
after a call to PN, its now connected
Message 2 of 3
(380 Views)
03-04-2013 2:43 PM
hey good to see you are up and running at last!
Now if you see any engineers in Hardwick please tell them to get their butts over to Caldecote, where the natives are definitely getting restless
Message 3 of 3
(380 Views)
- Full Fibre
