download speed reset
- Full Fibre
- download speed reset
04-04-2013 1:04 PM
Hi
The engineer came and connected up the fibre on tuesday & everything seems to be working fine.
Could someone take a look at resetting the download speed please? The person I spoke to at PN on the day said they would be altering the profile/speed/type thing once they saw the install was finished.
It was still unchanged last night, but I didnt get a chance to check this morning
Richard
Richard
Message 1 of 4
(2,185 Views)
3 REPLIES 3
Re: download speed reset
04-04-2013 1:27 PM
Hi
Glad you've finally been set up - taken a long time (before XMAS you were hoping for) to get it installed!
If you go to https://portal.plus.net/my.html?action=data_transfer_speed what does it say for current line speed? Does this match your IP profile in the BT Speed Checker when you go to further diagnostics?
Message 2 of 4
(488 Views)
04-04-2013 5:56 PM
IP profile is 38Mb
I'm still only getting 12.5 down (pretty much what I had before) & 9.5 up (20x what I had before
(I think I opted for the 40Mb fttp option way back in the dim and distant past, but that was before the unlimited options came out too, so I'll see about upping it to 80/20 unlimited when its all working ok. The 160Mb seems just the wrong side of expensive to me
I dont think my profile has been reset properly yet.
Richard
Richard
Message 3 of 4
(488 Views)
04-04-2013 11:17 PM
Have you tried disconnecting/reconnecting from your router?
The PN link I posted above should match your IP Profile - just a question of them amending it (if it's not been changed since your install).
Hopefully PN will offer some bundled telephone/Internet FTTP packages soon. The pricing is the same as FTTC/WLR with BTO so should be straightforward, it's just the faster speeds and unlimited bit that need working out.
Message 4 of 4
(488 Views)
