Why are plusnets maxiumum speeds slower than Virgin?
drFishFlan
I am very happy with my plusnet service... Good value and service.
I am just curious to know why virgin have such faster top available speeds than plusnet when they both run on fibre optics.
In my case I am on the fibre to the door trial so in theory there is no reason why it can't run faster?
4 REPLIES 4
Fixes: 395
Re: Why are plusnets maxiumum speeds slower than Virgin?
I believe FTTP is technically capable of up to 1Gbps.  Plusnet are still only offering fttp on a trial basis and have decided for the time being to only offer a product with comparable speeds to the normal FTTC product. I believe other suppliers of fttp will offer a 300Mbps product but it is considerably more expensive.
drFishFlan
Thanks for this .
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to FTTP Trial
Fixes: 49
@drFishFlan
Virgin have their own network and are free to offer whatever speed they want.
Those ISP's using the OpenReach have a choice of wholesale products at different speeds. PlusNet simply uses the standard 40/10 & 80/20 options (same as FTTC). Can't say offhand what the two normal higher speeds are but if you were to look at BT Retail you would see.
