Which package am I on?
- Full Fibre
- Re: Which package am I on?
07-11-2016 10:22 AM
Hi
Would someone be able to check which package I'm on please?
I think I should be on the 80/20, and have been since we started on the trial, but last few tests show more like 40/20
Richard
07-11-2016 12:27 PM
Welcome to the community forums @gunsmoke2
Looks like you're on an 80/20 package as you've said you think you should be.
Could you try a single disconnect/reconnect and let us know if you're still experiencing slower than expected speeds.
Thanks.
07-11-2016 12:42 PM
will do (this evening)
thanks
Richard
11-11-2016 10:23 AM
Only just got round to kicking the kids off long enough to do a speed test
Everything back to normal, thanks
Richard
11-11-2016 10:32 AM
