Upload speed increase ?
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Upload speed increase ?
01-03-2019 9:40 AM
Some time last year there was a notification from Plusnet of an increase in upload speed. I think we're still stuck firmly at 2mbps on our fttp, should we have been upgraded?
Many thanks
Fixed! Go to the fix.
01-03-2019 11:42 AM
Hi there, it looks like you're on an old variant of the FTTP trial that was provided on 40/2 speeds. We've no problem upgrading the upstream though. I've just popped an order through for that which should take effect before the end of the day on Monday.
04-03-2019 6:49 PM
13-07-2020 12:29 PM
Hello, how can I increase the upload speed of my connection?
14-07-2020 1:11 PM
Hi @Ditherton
Thanks for getting in touch.
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
-Piotr
- Full Fibre
