Upgrade to FTTP
- Full Fibre
- Re: Upgrade to FTTP
Upgrade to FTTP
01-03-2014 7:13 PM
Hi Plusnet,
I would like to enquire into upgrading if possible to FTTP. I understand there would be charges potentially, but what would be the process behind it? Currently on your FTTC product,
thanks!!
thanks!!
Message 1 of 6
(1,882 Views)
5 REPLIES 5
Re: Upgrade to FTTP
01-03-2014 7:13 PM
But is FTTP actually available
Message 2 of 6
(683 Views)
Re: Upgrade to FTTP
01-03-2014 7:34 PM
Lol Jim,
that's why I am asking! Unless there is a means of finding out other than this forum? I would like someone from Plusnet to give the official thoughts also!
thanks
thanks
Message 3 of 6
(683 Views)
Re: Upgrade to FTTP
01-03-2014 7:51 PM
If your local cabinet is FTTC enabled is unlikely BT are going to run fibre to the premises in your area.
Put your phone number in here which will tell you what is available in your area.
http://www.dslchecker.bt.com/
Message 4 of 6
(683 Views)
Re: Upgrade to FTTP
01-03-2014 9:03 PM
I guess the OP is enquiring about FTTP on demand, where in some area's you can get BTOR to run a fibre from the cabnet to your house.
It's very expensive though they recently put the prices up considerably as well
Message 5 of 6
(683 Views)
Re: Upgrade to FTTP
03-03-2014 3:03 PM
Hi buzz234,
If you have FTTC available then as a rule FTTP won't be available. Sorry if this causes an inconvenience.
Message 6 of 6
(683 Views)
