Static IP
- Full Fibre
- Re: Static IP
Static IP
09-10-2010 7:36 PM
The FAQ says that if you're on a static address with ADSL then you'll have a static on FTTC. The question is, is it the same static address or will it change when they switch you to the new service?
Message 1 of 5
(1,710 Views)
4 REPLIES 4
Re: Static IP
09-10-2010 7:55 PM
my static IP has not changed from ADSL to FTTC.
afaik, it won't change (or shouldn't) because it's what the plus.net servers allocate you when you connect/authenticate your connection rather than the 'route' it takes
Message 2 of 5
(935 Views)
Re: Static IP
09-10-2010 9:25 PM
That's what I'd guessed. I was looking for some official confirmation.
Good to hear that your's didn't change though.
Message 3 of 5
(935 Views)
Re: Static IP
09-10-2010 9:57 PM
Indeed,
Your static IP will be assigned to you, as your connection terminates in our network as normal.
Message 4 of 5
(935 Views)
Re: Static IP
10-10-2010 3:15 PM
Perfect. Thank you.
Message 5 of 5
(935 Views)
