Sporadic Performance Issues
dsbibby
The last few days I've been experiencing intermittent performance issues. Every few page loads one will hang for several seconds (10-20) or indefinitely, then it will be fine again.
I've tried the usual router reboot, and wired connection (rather than wifi) but no difference.
@Gandalf - is there anything you can look at to see if there is an issue?
Many thanks!
David
3 REPLIES 3
Fixes: 813
Re: Sporadic Performance Issues
Hi David
Our tests aren't showing any issues with your FTTP service. Is your wired connection a laptop/computer connected directly into your router using an ethernet cable without any switches or powerline adapters in place?
Do you also have a different router you can try?
dsbibby
Hi @Gandalf ,
Thanks for looking in to this... whatever it was seems to have healed - it's not done it for a few days now.
Good to know the FTTP service is OK from your end though.
Many thanks,
David
Fixes: 813
Hi David, no problem and I'm glad to see the issue seems to have resolved itself.
Feel free to let us know if you need any further assistance.
