Speed/profile issue
- Full Fibre
- Re: Speed/profile issue
Speed/profile issue
26-04-2015 9:44 PM
Hello please can my profile be reset? would be great if it could b e raised beyond 80/20?
http://www.speedtest.net/my-result/4318857569
DOWNLOAD
15.98Mb/s
UPLOAD
18.99Mb/s
http://www.speedtest.btwholesale.com/
1. Best Effort Test: -provides background information.
Download Speed
11.81 Mbps
0 Mbps 76.8 Mbps
Max Achievable Speed
Download speedachieved during the test was - 11.81 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-76.8 Mbps .
Additional Information:
IP Profile for your line is - 76.8 Mbps
Upload Speed
15.43 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 15.43Mbps
DOWNLOAD
15.98Mb/s
UPLOAD
18.99Mb/s
Download Speed
11.81 Mbps
0 Mbps 76.8 Mbps
Upload Speed
15.43 Mbps
0 Mbps 20 Mbps
Message 1 of 9
(3,198 Views)
8 REPLIES 8
27-04-2015 11:55 AM
It tests fine at the moment. Are you getting these speeds on a wired or wireless connection?
Message 2 of 9
(945 Views)
27-04-2015 12:10 PM
Thanks Matty its was wired, power cycled all the devices works ok today. maxing @ 64M it has been better though?
Message 3 of 9
(945 Views)
27-04-2015 12:33 PM
What gateway are you on? Check at http://usertools.plus.net/@gateway/.
I have issues with streaming when connected to the BNG gateways but not the AG gateways. On BNG I was also seeing a drop in the download speed into the mid 60's too.
Message 4 of 9
(945 Views)
27-04-2015 1:05 PM
Does this help?
Which gateway
You are currently connected to gateway ptn-bng01.
This is located in Telehouse North.
Which gateway
Message 5 of 9
(945 Views)
27-04-2015 2:51 PM
Sometimes the gateway which your router connects to, causes speed issues as the path varies from your premises to each gateway. It is always worth knowing which gateway you are on and if you see speed related issues, it can be worthwhile using the router to disconnect and then connect to see if a new gateway solves it. Your power cycle did that for you.
To see the number of users on each gateway for the last 24 hours look at http://portal.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml towards the bottom of the page.
So I guess it is just having that information to hand as it can help Plusnet identify issues if lots of people all complain about the loss of speed on the same gateway. For you, looking for patterns in the long term use so that when comparing speed tests, you can see if a particular gateway has some bearing on the results. I know that my results vary a lot by gateway.
Message 6 of 9
(945 Views)
18-05-2015 10:09 PM
Hi download speed @ 6M....You are currently connected to gateway pcl-bng02.
This is located in City Lifeline House.
Are there problems?
Are there problems?
Message 7 of 9
(945 Views)
16-06-2015 8:28 PM
it was fixed but its happening again - 11.41 down 20.29 up...apparently I was on the wrong Vlan before in the exchange?? please can this be checked?
You are currently connected to gateway ptn-ag03.
Message 8 of 9
(945 Views)
17-06-2015 9:03 AM
http://www.thinkbroadband.com/ping/share/4a98b7dd0804cece725022b6df7ce5de.html
problems during the evening
Message 9 of 9
(945 Views)
