Router upgrade
- Full Fibre
- Router upgrade
Re: Router upgrade
23-02-2011 5:41 PM
Re: Router upgrade
23-02-2011 6:40 PM
IMO you are not going to get very far in finding out where the bottleneck/problem is.
Re: Router upgrade
23-02-2011 6:56 PM
With any investigation such as this you start with the minimum amount of kit and add each piece as you go until the problem re-occurs.
Start with PC & extender only and prove both can work at gigabit speeds. If all OK add the switch and see if it can... if all OK add the next bit of kit and contionue until the problem occurs. Then work out what needs to be done to solve it knowing what is causing it.
Re: Router upgrade
23-02-2011 7:46 PM
My money is on the TP-link thing not being up to the job 🙂
If you're only getting 22Mb/s (mega-bits) then you have faulty kit. If you're getting 22MB/s (mega-bytes) then that's par for the course on cheap-ish kit. I only get 30MB/s between two cheap-o NICs at work simply because there isn't the I/O bandwidth in the PCs.
Re: Router upgrade
24-02-2011 9:57 AM
Quote from: oakwoods Novatech are stating the data will still pass through the router. He did make a point by stating that if it were possible to connect a gigabit switch and still achieve gigabit speed, then why would they make gigabit routers? A 10/100 router + gigabit switch is cheaper than a gigabit router.
Next they'll tell you your network is limited to the speed of your Internet as it's all connected It's FUD. If you use a HUB, not a switch, then they are correct. In fact with a switch, assuming it has sufficient processing power, you should be able to have a 2 pairs of devices talking and get a total used bandwidth in excess of what one port can do.
As others have asked what is the media extender you're using? If I read it correctly the software you are using is not really testing the LAN, IMHO, as it's ultimately writing/reading a file on the extender. Are your write and read speeds identical?
Re: Router upgrade
24-02-2011 10:07 AM
They were just trying to up-sell you...
Re: Router upgrade
24-02-2011 12:54 PM
In theory, connecting between two devices by IP address or netbios name will *not* need DNS. Nor will DHCP be required once both devices are up and running. The only time the router would be required is if the two devices lie on different subnets, and given the router in question I find this highly doubtful.
Please perform the following test:
1. Connect pc to switch, extender to switch, switch to router.
2. Restart pc and extender
3. Confirm connectivity between the two devices
4. Unplug router from the switch
5. Confirm connectivity between the two devices
6. Perform the transfer test
If you find that it is still transferring at low speed then you need to investigate possible causes such as checking both devices are actually working at 100BaseT full duplex or 1000BaseT (the lights on the switch should help here).
Novatech are talking rubbish basically. The reason routers come with gigabit ports is so that SoHo users don't need a separate switch.
Re: Router upgrade
24-02-2011 8:09 PM
Thanks for everyones help. It really is appreciated.
Re: Router upgrade
24-02-2011 10:49 PM
Re: Router upgrade
24-02-2011 10:56 PM
Re: Router upgrade
24-02-2011 11:10 PM
But as you say what you have should work.
Edit:
It could be that the Xstreamer is working ok but the PC/Hard drive you are streaming from is the bottleneck?
Have you tried disabling any anti-virus you have on the PC that you are streaming form (temporarily)?
Re: Router upgrade
24-02-2011 11:30 PM
Re: Router upgrade
25-02-2011 12:06 AM
Re: Router upgrade
25-02-2011 8:08 AM
Re: Router upgrade
25-02-2011 9:36 AM
Will it play a 1080p file from it's internal hard disk Ok?
