Rate limiting
- Full Fibre
- Re: Rate limiting
Rate limiting
15-04-2011 3:22 PM
I was just wondering, with the FTTC trial now over, does anyone know what the traffic management will be like on the fibre packages? Is there a page like this one for the new products?http://www.plus.net/support/broadband/speed_guide/download_speeds.shtml#extraSpeeds
Message 1 of 3
(9,571 Views)
2 REPLIES 2
Re: Rate limiting
15-04-2011 7:29 PM
I'm sure there will be alongside launch of the Fibre-based products. Won't be long now …
David
Message 2 of 3
(436 Views)
Re: Rate limiting
17-04-2011 5:17 PM
Yes, I had the same question. The answer is yes, from the 19th of April there will be a bolt on for the FTTC users ( almost like Plusnet pro) for an extra £5 there will be no traffic shaping. I use skype a lot and it is picked up by plusnet as peer to peer traffic which gets throttled a lot.
Message 3 of 3
(436 Views)
