Profile please
- Full Fibre
- Re: Profile please
Profile please
08-04-2011 9:47 AM
Username mwright Bt have connected us up to the trial and its all working with 37 meg connection. Can someone please do my profile as the speed tests only shows 5 meg so far cheers. Do we have to reset the modem or router one the profile has changed?
Message 1 of 7
(1,403 Views)
6 REPLIES 6
Re: Profile please
08-04-2011 10:05 AM
Done, and you shouldn't need to reset the router. Just give it 5 minutes and you should see the faster speeds.
Message 2 of 7
(599 Views)
Re: Profile please
08-04-2011 10:19 AM
Cheers cooking on gas now 34.5 meg down and 1.7 upload
Message 3 of 7
(599 Views)
Re: Profile please
08-04-2011 2:44 PM
Is there anyway on the supplied netgear router to see the connections speed snr etc cant find it or is it on the modem? Is there anyway to look at the stats on the modem?
Message 4 of 7
(599 Views)
Re: Profile please
08-04-2011 2:51 PM
Hi Samuria,
It should be in the links on the left on the router's home page, the top one should be 'Status' and should give you the information you need?
Message 5 of 7
(599 Views)
Re: Profile please
08-04-2011 2:55 PM
I'm not sure what router Matt's referring to there as the netgear I've got for FTTC doesn't have that option, I'll check shortly with him. It's also the modem that would provide the sync so unlikely that they are available.
Message 6 of 7
(599 Views)
Re: Profile please
08-04-2011 3:05 PM
Duly educated... my apologies
Message 7 of 7
(599 Views)
