Optical connection lost
Firu
Hi
I'm hoping that one of the Plusnet admins can help me out here. My FTTP connection went down this morning at about 9.20. When I checked the BT Openreach fibre modem the optical light was out. I turned it off and back on again and now the optical light is flashing and no internet. I really hope that the workmen down the road haven't done something to the fibre...
Cheers
Phil
8 REPLIES 8
RandallFlagg
Fixes: 75
Re: Optical connection lost
Hi Firu,
Thanks for letting us know you're having connectivity issues.
I've tested your connection and the results indicate that you may have an issue with your phone line which is impacting on your fibre.
Could you please check with your phone provider and ask them to test for any faults that may be present on your line?
Let us know how you get on.
Best wishes,
Dave
Firu
Hi Dave
Thanks for getting in touch.
I don't have an active phone line any more. I still have a physical copper cable coming into the house but I don't have an active connection on it. I deactivated my BT contract when I moved on to the Plusnet FTTP trial. Since it's an FTTP connection the fibre connection is completely separate from the copper cabling.
Phil
MatthewWheeler
Fixes: 479
Sorry to hear this.
Our tests are showing a potential issue so we've raised it for further investigation
We'll update you when we know more
 Matthew Wheeler
Firu
Morning
I noticed that my ticket (178596476) had an update on Saturday and is now off hold. I'd be very grateful for an update.
Phil
MatthewWheeler
Fixes: 479
Hi there.
I'll get this chased up for you and update the open ticket shortly
 Matthew Wheeler
Firu
Hi Matthew
Thanks for giving Openreach a nudge.
Cheers
Phil
Firu
@MatthewWheeler
My connection came back to life at some point yesterday and all appears to be ok with it. Is there any indication what the cause of the fault was and what was done to fix it?
Thanks for getting it sorted.
Phil
MatthewWheeler
Fixes: 479
Glad to hear it's sorted!
Unfortunately they've not provided any information as to why it happened or to why it was fixed.
Hopefully it doesn't happen again
 Matthew Wheeler
