My 80/20 with IP Profile 77mb = 35mb ????
- Full Fibre
- Re: My 80/20 with IP Profile 77mb = 35mb ????
21-04-2012 11:17 AM
Since trial started, i had about 75mb down with 15mb up...
Since the disconnections that a few had on Thursday, my connection has been Borked, despite rebooting Modem and router, sync rate settles the same......
BT IP Profile: 77.12mb (Down) - 20mb up
What i am receiving ? = 35mb Down - 15mb up (15mb up is normal since trial started)
Anyone else getting the same?
PN - Can you check your own settings against the BT one ?
and yes, speedtest bbmax reports same.. along with BT speedtest..
Message 1 of 4
(1,291 Views)
3 REPLIES 3
23-04-2012 11:06 AM
PN Staff....
Given i am on the trial, and this could be a setting that needs to be checked your end, do i need to raise a fault or is this something you can quickly check with regards to profiling ?
BT Profile - 77mb
PN - 36mb ?
BT Profile - 77mb
PN - 36mb ?
Message 2 of 4
(423 Views)
23-04-2012 11:06 AM
I've just tweaked your profile on our side, hope that's sped things up for you - should take effect pretty much straight away? Please let us know if not.
Message 3 of 4
(423 Views)
25-04-2012 10:46 AM
Running normal speed again...
Message 4 of 4
(423 Views)
- Full Fibre
