May i join the trials
- Full Fibre
- Re: May i join the trials
29-09-2010 11:52 PM
Can i join the fttp trials is it ready in my area
Message 1 of 8
(2,397 Views)
7 REPLIES 7
30-09-2010 3:57 PM
Looks like your exchange is enabled but we're still waiting on the cab, should be done at the end of the year, keep an eye on the availability checker here:
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
This will update once the cab is enabled.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 8
(1,051 Views)
01-10-2010 12:03 PM
When the cab is enabled do i get put on the trial automatically or do i have to apply for it.
Message 3 of 8
(1,051 Views)
01-10-2010 3:50 PM
You'd need to request it as it's a pretty big change and you'll need an engineer out so we'd need to arrange an appointment with you.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 4 of 8
(1,051 Views)
02-10-2010 2:08 AM
How do i go about requesting for this to happen when the cab is enabled.
Message 5 of 8
(1,051 Views)
28-10-2010 10:02 AM
how do i go about requesting this when the cab is enabled
Message 6 of 8
(1,051 Views)
28-10-2010 10:27 AM
Racki2008,
If Dave doesn't automatically contact you when your enabled then post back here. This is the place to request to be on the trial and Dave is excellent at responding.
Si
Si
Message 7 of 8
(1,051 Views)
28-10-2010 11:20 AM
As Si says either put a post in here and I'll send you an invite or the easier way is to raise a ticket via http://trials.plus.net once it's enabled as I pick them up most weekdays.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 8 of 8
(1,051 Views)
