May I join the FTTC tial
- Full Fibre
- May I join the FTTC tial
- « Previous
- 1
- 2
- Next »
Re: May I join the FTTC tial
14-01-2011 4:07 AM
Quote from: LittleOtik Well when the BT engineer installed my equipment he did indeed test my line and the results came up as D/L 40 meg and U/L 10 meg. So I should be getting more tham the ADSL checker says im entitle to, but i will settle for it none the less. Please get me sorted Dave! Thanks.
I suspect that the checker makes its prediction based on higher cable-fills, and so takes some crosstalk into account. The first people onto a cabinet (such as the ultra-keen triallists ) are therefore likely to get much better speeds at first, which will probably reduce as more people take up the service.
I bet the crosstalk behaviour is one of the things that BT want to discover from the trial...
Quote from: mikeyriot will the bt tester not tell you the echanges reported sync rate for VDSL?
Good point. If I ever get onto FTTC, I can see I'll be running more of these than I do at the moment!
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 16 of 17
(141 Views)
14-01-2011 4:29 PM
I'll let u know on tuesday if all goes well, unless someone beats me to it....
Message 17 of 17
(141 Views)
- « Previous
- 1
- 2
- Next »
