May I join the FTTC Trial?
- Full Fibre
- May I join the FTTC Trial?
Re: May I join the FTTC Trial?
16-08-2010 8:20 PM
"Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 19.7Mbps and upstream line speed of 7.9Mbps"
Have submitted a support question to ask for the trial the two new street cabs have been sitting there all shiny for about 6 or more weeks now, both aprox 400 yds from my house if you draw a straight line in either direction.
ADSL 2+ I'm getting 13.9mb / 1.1mb. The exchange is aprox 1.2 miles (of road) from here.
Regards,
Ashley
17-08-2010 7:07 AM
Quote from: dave In most cases they are installing new cabinets for FTTC sited next to the existing cabinets. In some cases they can put the new cabinet underground and a few of the existing cabs I think have been big enough to take the new kit as well but the vast majority are new ones next to the existing ones.
For my cabinet, they installed the new cabinet across the road from the original unmoved cabinet next to a large hedge by a field. I've also seen them relocate the original street cabinet a short distance and then install the new cabinet next to it. Openreach do appear, where possible, to try and mininise the visual impact of the new cabs.
Tom.
17-08-2010 10:12 AM
Let me see what we can do...
Edit: Ordered for the 6th
17-08-2010 10:22 AM
Quote from: Ben @AshleyHinton
Ben, thank you!
17-08-2010 10:27 AM
Quote from: tomm Openreach do appear, where possible, to try and mininise the visual impact of the new cabs.
Tom.
Their biggest issue from a visual point of view is that the new cabinets look fresh while the old
cabinets are often rusting, graffitied, and frankly look very old. This is certainly the case where I live.
Once FTTC is rolled out, maybe they should go back and at least paint the old cabinets.
Regards,
Ashley
17-08-2010 10:35 AM
17-08-2010 12:23 PM
Not sure if the following has ANYTHING at all to do with my order for the FTTC trial, (ticket 34710632 set to happen on the 27th of this month), but by chance i just looked at my PN member centre | connection settings | high speed broandband page. Its telling me my current line speed is 20,000.
Although my exchange has switched to 21CN, I have never moved onto an ADSL2 package, and so I'm on an up to 8MB line. Normally I see 6000-6500 for that stat, as my modem syncs around 6900.
Is this change to do with the FTTC trial order, should I be getting CS to look into it, or is it anything to be bothered about ?
Regards
Ian
17-08-2010 12:28 PM
17-08-2010 12:45 PM
"A regrade of this customer's line has not been possible. Please refund the relevant portion of the regrade fee"
Is this just some auto thing happening ?
17-08-2010 12:47 PM
17-08-2010 12:48 PM
17-08-2010 2:30 PM
I have a question logged requesting participation in the FTTC trial, just wanted to check something:
My exchange (Maidenhead) was due for upgrade September 30. According to dslchecker.bt.com, my line now currently supports FTTC. Does that mean I can get on the trial quicker?
Cheers
Paul
17-08-2010 11:13 PM
Will Openreach and the ISP's move to a self-install model at some point? I guess the problem comes where its a very old master telephone socket and its not just a case of replacing the face plate on the NTE5. Plus you never know what previous occupants have done - in my case when we moved in there was no master, and the extensions were just twisted off from the back of the first socket and insulated with sellotape!
Needless to say there is now a proper master NTE5 directly connected to the cable from outside and the phones & DSL work correctly.
Regards,
Ashley
18-08-2010 4:33 PM
18-08-2010 4:43 PM
Welcome to the forums Your line looks good so I'll place your order now
Edit: Booked in for 26th August, 1pm - 6pm.
