Max Speed Currently Offered?
cameldazzler
Hi All, we are currently on the trial for fttp and have been for some time, we have 80 down and 20 up, is this the maximum that is currently offered? can you offer the same as bt?
we have 2 fttp lins at the mo, one form zen and one from plusnet, it would be nice to get them both on the same speed (220/20) if possible.
Any ideas?
5 REPLIES 5
SpendLessTime
Fixes: 86
Re: Max Speed Currently Offered?
Plusnet only offer the same as the FTTC speeds , so 40/2 or 80/20 see staff post here
HarryB
Fixes: 256
Unfortunately it is correct that we currently only offer the same speeds for our FTTP Trial as we do for our FTTC packages. As SpendLessTime has said, 80/20 and 40/2.
 Harry Beesley
cameldazzler
Thanks Guys,
is there any likelihood that will increase in the future? just out of interest.
HarryB
Fixes: 256
I couldn't say to be honest. I don't believe there are any plans for it at the moment, but I'm not sure if/when that will change.
 Harry Beesley
Mav
Fixes: 515
Moderator's note by Mike (Mav)
I have reset the fix to SpendLessTime as it was his original link that was supplied to help the OP
Forum Moderator and Customer
