Just Signed up for FTTP
scimitar
Re: Just Signed up for FTTP
Thank you Warwick for a swift and detailed update. I have put some comments on my account under Question #178327433 - Your Feedback.
I look forward to future updates on the order.
Regards
Roger
Fixes: 36
Hi @scimitar,
I have responded to the ticket on your account which you can view via this link
https://www.plus.net/wizard/?p=view_question&id=178327433
If you have any further questions please do not hesitate to get back to us
Kind Regards,
 Satss
scimitar
The FTTP order update is due from today. Grateful if a PlusNet Help team member could chase this up.  Is there any progress please?
Regards
Roger
Fixes: 20
He @scimitar.
Thanks for getting in touch again, I appreciate you asking for an update.
I've responded to your query here.
Let us know if you need anything further.
Thanks.
  Tahir M
scimitar
I had a call this morning from CCN Communications ( [Removed]) who do sub contact work for BT. They will be coming to my property on the 9th October to install a small joint box in the road and a duct running from this box to my property. There is no requirement to close the road.
Regards
Roger
Moderator's note by Adie (Dvorak) removed personal details of contractor.
Fixes: 29
Hi @scimitar
Thanks for getting in touch regarding your installation.
I am glad that you have been given a date for this external work to be completed, I would advise that any information we provide regarding the order is cascaded through our suppliers as a result of surveys which is why we advised that the road closure is required.
If the sub contractor has advised you differently then this may be as a result of the location of the box may meet their safe practice without closure. As it stands we have not been given any update to that effect from our suppliers.
 Warwick
scimitar
For information, the external work including the duct work was completed on 9 October. The duct and a blue pull through rope terminates at my house. No Fibre cable has been run in the duct yet so I assume this will be the next stage.
I will await your response from the supplier.
Regards
Roger Collins
Seasoned Pro
Fixes: 9
@scimitar
A blue pull rope in place is a very good sign!!!
Assuming you're on a " connectorised " install one end of the fibre cable will have a factory installed connection so only the house end needs "fused" on the day - should now be an easy job to run the cable, get it into your house and the ONT deployed (famous last words!!!).
Fixes: 12
Hi @scimitar,
I have left a ticket on your account with an update. You can view this here
Should you have any further queries, please let us know.
Thank you,
Aisha
 Aisha Khan
scimitar
Grateful if Plusnet help Team could check with OR for an update on my FTTP order. All the external duct work etc was completed on 9th October.
Regards
Roger
Fixes: 36
Hi @scimitar
I have spoken with our suppliers today regarding your FTTP order and have updated you here
Kind regards,
 Satss
scimitar
Could a PN staff member please chase up the FTTP order update please with OR. No update has been given on my ticket number #178327433. As I have mentioned earlier all the external work has been completed ( 9 Oct) and the duct is ready to receive the FTTP cable and then ONT installation. Thank you.
Regards
Roger Collins
Fixes: 36
Hi @scimitar
Sorry for the lack of updates, I have updated you with the latest information on your FTTP order here
Should you have any further questions please do not hesitate to get back in touch.
 Satss
scimitar
Thank you very much for the swift update. I will look forward to the next OR visit.
Kind Regards
Roger
Fixes: 31
No problem @scimitar,
Just for confirmation, I have updated the ticket and you can access it here.
Thank you.
 Lewis G
 Infrastructure Operations Professional
