I'm about to go
krusty
Re: I'm about to go
Everything what RealAleMadrid said, but it goes in the lan4/wan port. Also you have to reconfigure the network setting on the archer to pppoe and your pn user/pass
Sidthree
Re: I'm about to go
Hi RealAle,
I have connected the router via an ethernet cable, as you describe, with my PN username and password.
As for the instructions, I can't remember exactly what they are but there is the option to select PN VDSL (with user name and p/word) and I'm (almost) certain that a PPOE connection is selected as default with this VDSL config.
Other than that, I can't be any more specific. What I'll do later, is to go through the setup again and pay attention to the setup config.
It must be something silly I'm doing, or not, which is the issue as it all worked fine before the ONT.
Sidthree
Re: I'm about to go
Hi Krusty,
Yep I have my cable in the lan4/wan port.
I will check the PPPOE stting once everyone is off the net and then I'll get back to you.
Thanks for your assistance.
Sidthree
Re: I'm about to go
Hello guys,
I have checked the TP-Link connection and, as you can see, pppoe is default selected.
Sidthree
Re: I'm about to go
Please ignore the attachment, it is a copy of the inserted images. My error, sorry.
SpendLessTime
Fixes: 86
Re: I'm about to go
@Sidthree
Have you changed the Operations Mode to be "Wireless Router Mode"?
Remember as you are not using the modem part of the device since you are connecting to the ONT so you need to ensure the device knows that.
Taken from TPLINK help at https://www.tp-link.com/ae/faq-1201.html
Sidthree
Re: I'm about to go
Ah, good point. I'll check, cheers.
Sidthree
Re: I'm about to go
DSL Modem Router mode is selected.
I gave 2G/4G Router mode a go too but nowt.
No connection.
SpendLessTime
Fixes: 86
Re: I'm about to go
@Sidthree
So there wasn't a "Wireless Router Mode" option to select then?
Weird as that option appears on the TP-Link Archer VR600 emulator.
Do you have the latest firmware on the TP-Link?
Sidthree
Re: I'm about to go
Hi SpendLessTime,
What's really weird is my, apparent, inability to read people's posts correctly!
I misread your earlier post as make sure the Modem Router option is selected; what a twit.
I have seleted wireless router and it has worked. You're a star, nice one. Thanks.
SpendLessTime
Fixes: 86
Re: I'm about to go
@Sidthree
You're welcome. And to admit to initially doing the wrong thing but then correcting it, is helpful to anyone else who follows in your footsteps.
krusty
Re: I'm about to go
we've all been there and done it .. so. Smiley As long as @Sidthree gets his modem/router into router only mode its all good
Alex
Fixes: 13
Re: I'm about to go
I'm with @SpendLessTime here.
Thanks @Sidthree for admitting how you fixed the problem.
It will no doubt help others who have been in the same situation as yourself and probably have done the same thing.
It makes a change reading posts where people say what they did to fix it, rather than disappear once everything is working and not say anything.
Sidthree
Re: I'm about to go
A big thank you goes to all you folks offering advice, help and wisdom. Thumbs_Up Cheers.
