I'm about to go
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: I'm about to go
- « Previous
- Next »
Re: I'm about to go
25-06-2018 5:03 PM
Everything what RealAleMadrid said, but it goes in the lan4/wan port. Also you have to reconfigure the network setting on the archer to pppoe and your pn user/pass
Re: I'm about to go
25-06-2018 6:26 PM
Hi RealAle,
I have connected the router via an ethernet cable, as you describe, with my PN username and password.
As for the instructions, I can't remember exactly what they are but there is the option to select PN VDSL (with user name and p/word) and I'm (almost) certain that a PPOE connection is selected as default with this VDSL config.
Other than that, I can't be any more specific. What I'll do later, is to go through the setup again and pay attention to the setup config.
It must be something silly I'm doing, or not, which is the issue as it all worked fine before the ONT.
Re: I'm about to go
25-06-2018 6:35 PM
Hi Krusty,
Yep I have my cable in the lan4/wan port.
I will check the PPPOE stting once everyone is off the net and then I'll get back to you.
Thanks for your assistance.
Re: I'm about to go
26-06-2018 11:37 AM
Hello guys,
I have checked the TP-Link connection and, as you can see, pppoe is default selected.
Re: I'm about to go
26-06-2018 11:39 AM
Please ignore the attachment, it is a copy of the inserted images. My error, sorry.
Re: I'm about to go
26-06-2018 12:20 PM
Have you changed the Operations Mode to be "Wireless Router Mode"?
Remember as you are not using the modem part of the device since you are connecting to the ONT so you need to ensure the device knows that.
Taken from TPLINK help at https://www.tp-link.com/ae/faq-1201.html
Re: I'm about to go
26-06-2018 12:24 PM
Ah, good point. I'll check, cheers.
Re: I'm about to go
26-06-2018 1:10 PM
DSL Modem Router mode is selected.
I gave 2G/4G Router mode a go too but nowt.
No connection.
Re: I'm about to go
26-06-2018 1:26 PM - edited 26-06-2018 1:27 PM
So there wasn't a "Wireless Router Mode" option to select then?
Weird as that option appears on the TP-Link Archer VR600 emulator.
Do you have the latest firmware on the TP-Link?
Re: I'm about to go
26-06-2018 3:04 PM
Hi SpendLessTime,
What's really weird is my, apparent, inability to read people's posts correctly!
I misread your earlier post as make sure the Modem Router option is selected; what a twit.
I have seleted wireless router and it has worked. You're a star, nice one. Thanks.
Re: I'm about to go
26-06-2018 3:08 PM - edited 26-06-2018 3:09 PM
You're welcome. And to admit to initially doing the wrong thing but then correcting it, is helpful to anyone else who follows in your footsteps.
Re: I'm about to go
26-06-2018 9:39 PM
we've all been there and done it .. so. As long as @Sidthree gets his modem/router into router only mode its all good
Re: I'm about to go
27-06-2018 8:02 AM
I'm with @SpendLessTime here.
Thanks @Sidthree for admitting how you fixed the problem.
It will no doubt help others who have been in the same situation as yourself and probably have done the same thing.
It makes a change reading posts where people say what they did to fix it, rather than disappear once everything is working and not say anything.
Re: I'm about to go
27-06-2018 6:03 PM
A big thank you goes to all you folks offering advice, help and wisdom. Cheers.
- « Previous
- Next »
