I'm about to go
Sidthree
I'm about to go
I asked to join the FTTP trial on 3/05/18, responded to the various agreements and have heard nothing since.
I'm getting fed up with being fobbed off, online agents saying they'd asked me to agree to stuff they'd never mentioned. having to wait for routers that were never sent, having to buy my own router and questions remaining unanswered.
I'm also fed up with 0.8 - 1.3mb d/loads and .3 - .7kb uploads.
I will be leaving you lot after many many years
Fixes: 226
Re: I'm about to go
Moderator's note:
Moved from Fibre Broadband to FTTP trial.
Forum Moderator and Customer
Fixes: 212
Re: I'm about to go
Apologies for the delayed response
We'll get this chased up for you
 Matthew Wheeler
Fixes: 6
Re: I'm about to go
@Sidthree
As it's a trial the FTTP service is not integrated with the PlusNet back office systems. Generally speaking phone and live chat support staff know little if anything about FTTP.
This forum (Fibre to the Premises) is the best place for support.
One thing to consider if you move is the price. PlusNet is by far the cheapest if you don't need your phone line. Even with a phone service I believe PlusNet is the cheapest (though I stand ready to be proved wrong).
Sidthree
Re: I'm about to go
Thank for that Brian, I get what you're saying about the phone and chat support bods, it's just the apparent inactivity around the whole business. Not to mention paying for the privilage of rarely reaching 1mbps d/load and a massive 12 - 50kbps u/load! Paying the same as someone with quadruple and more than that transfer rate.
I still have no idea of what, where, when, or indeed who, is happening right now!
Because I can't be a***d right now I'm giving it one more week, then that's it. I mean it this time, oh yes I do. No, no, nope, there'll be no turning back then. Oh no siree!
Sidthree
Re: I'm about to go
Oh, and that well known ISP John Lewis does a fibre with phone package cheaper.
Fixes: 33
Re: I'm about to go
Is FTTP available to you? I don't believe John Lewis offer it, they do offer FTTC.
Post the results of putting your phone number into the DSL Checker - the forum will be able to help give you more information.
Fixes: 6
Re: I'm about to go
Bear in mind PlusNet run John Lewis - so technically you'd be dealing with the same company.
krusty
Re: I'm about to go
What exactly have you ordered Sidthree?
FTTP or FTTC ...
As they are completely different things.
FTTC typically takes 7 to 14 days to install.
FTTP typically takes between a month to a year to install (depending on OR issues which are not PN related)
As far as i know John lewis does not support fttp.
Fixes: 6
Re: I'm about to go
@Sidthree
If you are talking about a FTTP installation then there are very few ISP's who offer a product. OpenReach list the following on their website.
https://www.homeandbusiness.openreach.co.uk/fibre-broadband/ultrafast-broadband/ultrafast-fibre-buy-...
Sidthree
Re: I'm about to go
Hi Mustrum,
Yes, FTTP is available and waiting.
Sidthree
Re: I'm about to go
Crumbs! So Plusnet own John Lewis and BT owns Plusnet. What a carve up!
Sidthree
Re: I'm about to go
I ordered FTTP. To do so I have had to buy the Fibre Unlimited package (FTTC); with my cabinet almost 2 miles away I am getting virtually the same transfer as before.
Sidthree
Re: I'm about to go
Thanks BMC.
Fixes: 6
Re: I'm about to go
Not quite that bad.
PlusNet are under contract from John Lewis to run their service for them.
