How can I find out if i can get FTTP?
conorandlucy
Can i get FTTP?
BT Checker says
FTTP on Demand 330 30 -- Available
Seasoned Pro
Fixes: 7
Re: How can I find out if i can get FTTP?
The short answer is yes, but not from PlusNet and not without a large hit on your wallet.
FTTP on Demand is basically for businesses and is offered by few ISP's. You have to pay for the installation from the nearest fibre aggregation node and then large monthly fees.
What you need to see on the DSL checker is WBC FTTP in the left had column and a column to the right of the results which will show "1 stage" or "2 stage"
If you can get VDSL then it's unlikely (but not unknown) that you'll get WBC FTTP
conorandlucy
Thanks.
Here is the whole table
Exchange MILTON KEYNES is served by Cabinet 51
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 74.5 20 19 66.6 Available -- -- Yes --
VDSL Range B (Impacted) 80 71.3 20 19 58.4 Available -- -- Yes --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- -- -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 6 -- 3.5 to 8.5 Available -- -- -- --
ADSL Max Up to 4.5 -- 3 to 7.5 Available -- -- -- --
WBC Fixed Rate 2 -- -- Available -- -- -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- -- -- --
ADSL Multicast -- -- -- Available -- -- -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 16-05-2017
Fixes: 186
You need to see WBC FTTP in the left hand column.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
conorandlucy
Ok, so by that reckoning its a no.  Oh well Smiley
Seasoned Pro
Fixes: 7
It's a definite NO unless you're willing to pay!!!
However, from the figures for VDSL you must be getting a decent FTTC speed.
Fixes: 6
