Help switching from BT to Plusnet
lindy
I'm currently with BT not out of choice but because it was the only available provider due to my FTTP connection. My contract is up at the end of April and they have advised that I will be charged £49.99 a month for their 76mb package which seems expensive compared to the £31.99 Plusnet package for the same speed.
I would like to move to Plusnet and have seen people have managed to do this through moving to an ADSL connection then joining the FTTP trial but I'm at a loss as to how I do this and what steps I need to take in what order.
Please could someone advise what steps I need to take to do this, it would be much appreciated.
9 REPLIES 9
Browni
Aspiring Hero
Fixes: 60
Re: Help switching from BT to Plusnet
First of all you need to check if ADSL is available!
What does this show (obscure any personal info)
lindy
Thank you for the information and link I have checked my number and get the following error message.
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line.
The line has been active for over 18 months so I'm not sure what the issue is.
HarryB
Fixes: 256
Have you tried the address checker option?
I'm not 100% sure if dslchecker will advise of availability for the number if the phone is also provided over fibre
 Harry Beesley
lindy
Hi, thank you for the reply.
I have checked using my address and get the following information:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP Install Process
WBC FTTP Up to 330 Up to 50 -- Available 2 Stage
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available --
HarryB
Fixes: 256
I'm afraid it looks like you may be in an FTTP only area Sad
I'm sorry to say we wouldn't be able to provide a service for you to become an existing customer and therefore become eligible for the fibre trial.
 Harry Beesley
lindy
Thanks for your reply and how disappointing.
I think it's disgusting that I'm stuck with BT's extortionate rates as there's no competition or other options Sad
Do you know when Plusnet will rollout FTTP?
HarryB
Fixes: 256
I'm afraid I don't have any information on if/when that may be Undecided
 Harry Beesley
Mustrum
Fixes: 77
@lindy no need to stick with BT, have a look at this ISP Review article for some other options.
Fixes: 49
@lindy
Have a look at the following website. Under the menu heading Fibre Broadband there is a sub heading "Ultrafast Broadband"
Click on this and then another clicks will take you to a list of companies who provide a FTTP service. Don't know many of them but Zen Internet could be worth a look.
https://www.openreach.co.uk/orpg/home/index.do
