Fttp is showing as available.
keyholder
Hi.. according to the btwholesale checker FTTP 330/30 is possible to my house as per a phone number check..
Are pn still offering FTTP deals ?
18 REPLIES 18
Fixes: 48
Re: Fttp is showing as available.
Does it say something like "WBC FTTP" or "FTTP on Demand" on the DSL checker.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If the former then PlusNet are still running a trial for existing customers.
Pete11
Seasoned Pro
Fixes: 4
It's also showing as available here...
FTTP On Demand  330/30 Available
WBC FTTC  Available
I wonder how much that will cost..or is it 'mates rates' for trialling it?
Any help from PN on this one?
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Fixes: 48
You're out of luck!!!
FTTP on Demand is not offered by PlusNet. Even if it was, it's an extremely expensive product which is more suited for business.
I'm assuming WBC FTTP is shown along the top menu. It's the menu down the left hand side that counts.
Pete11
Seasoned Pro
Fixes: 4
@bmc
FTTP on Demand is the on the menu down the left hand side.
But that's just typical of my luck..pfffft. Oh well, I can still dream. Roll_eyes
RealAleMadrid
Aspiring Hero
Fixes: 59
If it doesn't have WBC FTTP in the Featured Products Column (Far left hand side of the checker output) you can't have it. PlusNet do not offer FTTP on Demand which is aimed at business use and costs £thousands to install and around £300 a month on a 3 year contract, unless you're made of money.Smiley
Pete11
Seasoned Pro
Fixes: 4
Ok...time for the Yorkshire battle cry...HOW MUCH????
Blimey, I wonder if the 'powers that be' are distant relatives of Dick turpin.  Shocked
Fixes: 48
If you already have a VDSL service then you're unlikely to get FTTP in the near future unless one of the alternative suppliers is in your area.
keyholder
@bmc
Yes. It's says both.. but also shows fttpod is available with published speeds. So it's telling me I can get FTTP delivered.. and with the local cab being at the bottom of our road providing the link don't come directly from the exchange then I can't see it being expensive to provide.
keyholder
@realale.. Yes it's down the left hand side with published speeds.
My pn contract is due to end in 2 months so I'm already looking for either fttpod or 100mb leased line which is still cheaper than the £300pm but not by much.
Browni
Aspiring Hero
Fixes: 60
Plusnet don't supply FTTPoD.
keyholder
@bmc
Just put in for a trial .. so fingers crossed.
Browni
Aspiring Hero
Fixes: 60
Good luck but if the DSL checker doesn't show WBC FTTP I'm afraid you'll be disappointed.
keyholder
@brownie
It does.
Fixes: 48
@keyholder
I'm a bit confused by what the DSL checker says. Can you post a screen image of the results. If not, can you confirm "WBC FTTP" is shown on the menu down the left hand side (it'll also appear on the top menu).
FTTP is not supplied via the FTTC cabinet. If you have such a beast nearby then you would be a very lucky person to also have FTTP though I guess it's not unknown.
FTTP is provisioned on it's own network. To supply "FTTP on Demand" OpenReach need to run cable to the nearest fibre aggregation point which could be anywhere - hence the possible large costs.
