FTTP - new install (28th) - initial speedtests
- Full Fibre
- Re: FTTP - new install (28th) - initial speedtests
29-09-2011 5:56 PM
FTTP installed yesterday, initial BT speedtests today are:
Downstream (a.m.) : 18,841 Kbps (p.m) 18,826 Kbps
Upstream (a.m.) : 6,211 Kbps (p.m) 13,667 Kbps
BT rate max as :
Down - IP Profile for your line is -106,417 Kbps
Up - IP profile on your line is - 15,000 Kbps
looking forward to getting that max download - have not tried tweaking anything this end to improve it.
Jack
BT rate max as :
Jack
Message 1 of 8
(1,855 Views)
7 REPLIES 7
30-09-2011 8:21 AM
30-Sep-2011
Downstream (a.m.) : 18,795 Kbps (p.m)
Upstream (a.m.) : 15,072 Kbps (p.m)
I'm wondering if my downstream rate is being throttled by some setting or a very low sync rate. Anything I can check my end?
p.s.
router is a ZyXel NBG4604, not the Netgear it says on my Plusnet account
p.s.
Message 2 of 8
(782 Views)
30-09-2011 8:26 AM
Try another one in 5 minutes
Your account hadn't been updated on our system to match the FTTP speeds.
Message 3 of 8
(782 Views)
30-09-2011 9:18 AM
Thanks Chris,
I ran another test at 8:58 and got 18,836 Kbps down, with 15,361 Kbps up.
Maybe the setting takes a while to propagate around? I'll try another test around lunchtime.
Jack
Jack
Message 4 of 8
(782 Views)
30-09-2011 9:20 AM
Do you connect to the router wired or wireless?
Message 5 of 8
(782 Views)
30-09-2011 9:36 AM
Quote from: jelv Do you connect to the router wired or wireless?
For running the speed test I use a wired connection and the wireless LAN is disabled atm.
Message 6 of 8
(782 Views)
30-09-2011 10:27 AM
Tried another test at about 10:05, after powering off and on the modem & router respectively, and got:
Down: 53,153 Kbps
Up: 12,973 Kpbs
Down: 53,153 Kbps
Up: 12,973 Kpbs
Message 7 of 8
(782 Views)
05-10-2011 3:21 PM
Using http://www.thinkbroadband.com/speedtest.html ; today
Speed Down 100203.16 Kbps ( 97.9 Mbps )
Speed Up 15366.42 Kbps ( 15 Mbps )
Woo and indeed Hoo
Woo and indeed Hoo
Message 8 of 8
(782 Views)
- Full Fibre
