FTTP large speed variations - is there an issue?
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: FTTP large speed variations - is there an issu...
27-02-2018 10:45 PM
After my FTTP installation on the 5/2/18 the initial speed tests showed lo 70Mbps download and low 20Mbs upload. Perfect!
After a while I noticed some website loading issues and even iPlayer buffering. Re-running speed tests on the 22/2/18 I discovered I was getting mid 30s Download, which later upped to 60, then 70Mbs.
On the 23/2/18 I saw download speeds drop to 28, 31,51, 31Mbs
I currently seem to have 56 Mbs download. Throughout the upload speed has been consistently 20+Mbs.
Can someone please look into this?
Cheers
Steve
Fixed! Go to the fix.
Re: FTTP large speed variations - is there an issue?
28-02-2018 4:53 PM
Only 35 Mbs today... half the initial speed
What's going on?
05-03-2018 1:23 PM - edited 05-03-2018 2:32 PM
Are you using the Plusnet Hub One (A rebranded BT Home Hub 5)? If so this could be the issue with your connection. I found with mine the speed would drop down after about 3 days to roughly half the download (35Mbps) and rebooting the router would fix the issue - this was especially a problem with Wi-Fi, the wired part would eventually give up too.
If this is the issue you can resolve it by the following:
1) Reboot the Hub One at least every other day - This is the free option!
2) Replace the Hub Once with a BT Ultrafast Smart Hub - this is the WAN compatible version of the Standard BT Smart Hub - as the regular one does not have the red WAN socket on, and will not work. I picked mine up off eBay for £25 - this was brand new in box. I can confirm that the one I have works for plusnet fttp trial - but ymmv. On ebay they are variably described as WAN, FTTP or Ultrafast, you need to look at a photo of the rear of the router to determine if it has the red wan socket or not - or ask the seller the question, sometimes the seller will just describe it as a regular BT Smart Hub. I noted they come up pretty regularly and you can get one for under £30 if you hold out and get a little lucky! You need to put your Plusnet username and password in to get it working - it won't just work out of the box, but this is very easy to do. This is the cheap option!
3) Buy a non ISP supplied router to replace the Hub One - to get a decent spec one I would say you're looking at £100+
I personally haven't noticed any speed drops if it isn't router related!
05-03-2018 2:38 PM
Hmmm... I'm sure that this is just the thing that Plusnet need to know about as part of the trial, if their router is not fit for purpose.
I have to say the speed recovers from time to time and varies depending on which host the speediest uses. This suggests a network/throttling issue to me, more than router hardware. I wonder if Plusnet networks people have a view.
05-03-2018 3:10 PM
Are you testing using wired or wi-fi ?
If wi-fi then there is always the possibility of local interference.
05-03-2018 3:13 PM
05-03-2018 3:24 PM
wifi... 75mb download 22mb upload today! ...and I've done precisely nothing.
If it's wifi interference it's very sporadic, furthermore how would we detect this (packet loss? jitter?).
If it's router hardware (as has been suggested) then we could say the router is not fit for purpose to provide a reliable 70mb connection. I don't think it's this.
I'm still wondering what Plusnet make of this. After all, isn't that why there is an fttp trial group, so Plusnet can discover and iron out any potential issues?
05-03-2018 7:41 PM
@SJP if I was you pop to Maplins and but a new Wan DHCP router. you should be able to get it at cost from them under their current circumstances! and then try that. My preferance is Netgear but t-link are good as well.
05-03-2018 7:53 PM
Nature of the beast.
06-03-2018 9:55 AM
I agree Wi-Fi can be variable and wired is the best way to test your line speed. However, my experience with the Hub One (and Home Hub 5) is that they consistently drop in speed over the course of several days, which is immediately remedied by rebooting the router, I have had mine swapped, so I have eliminated my problem being with a specific unit.
After I switched to the BT Smart Hub it remedied the Wi-Fi slowdown I had been experiencing, and the wi-fi was much more stable. I had the same problem when I was on FTTC at a previous house.
Though the OP's issue may not be that, I certainly would test rebooting the Hub One router and retesting speed to see if it immediately goes back up to full speed. If the speed remains low then it may well be a line issue.
06-03-2018 9:43 PM
Reading these last two posts I am glad I have a Netgear Nighthawk! If I had a HH5 and the service was that bad it would of been lump hammered and binned long ago!
06-03-2018 11:05 PM
07-03-2018 4:36 PM
I'd recommend trying a wired connection. If your performance is OK in this way, then the steps in this troubleshooting guide should help: https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
07-03-2018 4:58 PM
There's been quite a few suggestions... From reboot every other day to swap my router... I decided to just monitor matters. Guess what I found? Consistent 70+ downloads and 20+ uploads for several days, after doing precisely nothing.
What this suggests to me is, firstly the issue has gone away; secondly the problem (when there is one) lies within the external network. I don't know if it is a throughput bottleneck or a traffic throttling issue. What I can say is, I am currently getting the desired speeds, without any changes to the installed hardware.
I'll keep monitoring and report back.
07-03-2018 5:19 PM
- Full Fibre
