FTTP coming to my area
strongylad28
Re: FTTP coming to my area
Thankyou very much for the quick turn around! I don't mind waiting 3 weeks for the install, it's taken long enough so far so what's another three weeks 😂
One last question, am I right in thinking the one hub is a rebranded HH5A? Would there be any issues in me using my existing HH?
Fixes: 1,600
No worries. I'm keen to resolve this for you after following this thread for so long. Smiley
Essentially yes. And no, I don't see any problems with that, providing it's a fibre modem/router.
You'll need to configure it though with your account details, but this guide should help out: https://www.plus.net/help/broadband/broadband-connection-settings/
strongylad28
I really appreciate your help with it all! I'd be happy to give feedback on your help as soon as it's all installed.
Will my login details be the same as my ADSL ones? As I'm using the hub now and it could be a simple switch over.
I'll give the one hub a try first though if it's the same as the HH because mine is a couple of years old now
Fixes: 48
@strongylad28
With regard to your install - if I remember correctly OR previously ran a cable to your house which is currently coiled up outside. So it would only require to be brought inside and an ONT installed.
You can see details of the PlusNet Hub One here
> Setting up and using your PlusNet router
strongylad28
@bmc that's correct. It's all coiled up outside at the moment so fingers crossed it will be a smooth install!
Fixes: 48
I would image that, unless it's been checked previously, the cable run for the fibre is the most uncertain part of the install (my house had draw rope left in place by the network install team!!!). Once that's done the rest is straightforward.
The last two installs on my street have used the original telephone wire entry point so they didn't even have to drill a new access to the house. Both had their ONT installed just below the master socket so only a couple of inches of fibre is visible.
SpendLessTime
Fixes: 86
@Gandalf
Isn't a HH5 (and Hub One) a VDSL device where the modem cannot be switched off while those of us on the FTTP trial need a router (which doesn't require a modem)
strongylad28
I thought this, as the ONT is effectively the modem if I am correct?
SpendLessTime
Fixes: 86
@strongylad28
Yes the ONT is the terminator so effectively a modem. And the output from the ONT is to a router WAN connection using Cat 5 ethernet cables and not the phone signal like a VDL Device expects.
RealAleMadrid
Aspiring Hero
Fixes: 59
You do not actually need a VDSL2 modem router for FTTP, the ONT is effectively the modem. The router has to have an Ethernet WAN port to connect to the ONT, the BT hubs and PlusNet Hub One have this (apart from HH6 which has a different version for FTTP)
strongylad28
I have the HH5, and the one hub so I'm pretty sorted for now. But something to note in the future if I decide to upgrade my router
David_Haigh
@strongylad28 Feel a Champagne and ticker tape moment! Hope you have the beers on ice!
strongylad28
I'll be using a giant pair of scissors to cut a silk rope around the router come the 26th April!
Fixes: 1,600
Yep, that's right.
The Hub One works with the ONT box, as I suspect the Homehub 5 will but I can't be sure.
I'll break out the whiskey. Cheesy
David_Haigh
@Gandalf Would of thought you already had a saw head from banging it against the OR wall!
But another victory for the PN Mino over big brother!
