[FTTP] Wireless performance of Netgear WNR3500
- Full Fibre
- Re: Wireless performance of Netgear WNR3500
25-10-2010 7:48 PM
I've configured the router to Channel 6 ( the best performing channel ) and I'm testing with no other wireless devices active from my 3 month old MacBook Pro
These are the results.
Speed test from mybroadbandspeed.co.uk
Same room
up to 145MbpsMode
Today 18:05 91486 kbps (11.4MB/s) 15193 kbps (1.9MB/s)
Today 18:06 91288 kbps (11.4MB/s) 15189 kbps (1.9MB/s)
Today 18:08 91227 kbps (11.4MB/s) 15198 kbps (1.9MB/s)
up to 300MbpsMode
Today 18:11 86717 kbps (10.8MB/s) 15191 kbps (1.9MB/s)
Today 18:11 88893 kbps (11.1MB/s) 15195 kbps (1.9MB/s)
Today 18:10 86369 kbps (10.8MB/s) 15194 kbps (1.9MB/s)
2 Rooms away
up to 145MbpsMode
Today 18:16 35275 kbps (4.41MB/s) 13836 kbps (1.73MB/s)
Today 18:16 49367 kbps (6.17MB/s) 14685 kbps (1.84MB/s)
Today 18:15 37238 kbps (4.65MB/s) 15074 kbps (1.88MB/s)
up to 300MbpsMode
Today 18:21 37742 kbps (4.72MB/s) 8471 kbps (1.06MB/s)
Today 18:21 41327 kbps (5.17MB/s) 11495 kbps (1.44MB/s)
Today 18:19 46806 kbps (5.85MB/s) 11700 kbps (1.46MB/s)
My Mac is saying the link speed is 144 Mbit/s regardless of the speed setting I select above.
I though standard 2.4ghz N was supposed to be up to 144 and 5.0ghz was supposed to be up to 300....
Would I be right in thinking 5ghz N is only possible if you have a netgear card in your computer ?
Are these figures reasonable ?
I've just ordered an Airport Extreme on line to see if that help as we have 2 MacBook Pro's and iPhone which are the most important devices.
Si
26-10-2010 8:58 AM
I've got a little Acer Revo which was only £265 and I have that on 24/7 connected to a 4TB NAS and ethernet to the router. I then use my vaio or MBP (or indeed my phone most of the time, HTC Desire) for general surfing and to queue up downloads on the Revo (all the ports are open so I can remotely set downloads going from any other device). Since you're an Apple fan, maybe get a little AppleTV for this purpose. You could also run XBMC on it as a nice little HTPC as I do with the Revo.
26-10-2010 9:42 AM
I'm a little shocked by your post as you appear to be mirroring my life exactly.........I'm running XBMC on the Revo connected to a 4TB NAS box with open ports to remotely add downloads.....via my MacBook Pro or HTC Desire LOL Are you called Simon ????
Back on Topic, I'd expect a router that boasts 300mbs to give better then 40mbs in the next room.
Like I said I suspect this is due to incompatible wireless hardware so when I my Airport Extreme arrives I'm hoping to see wireless improvements.
I guess I just posted this as I was disappointed at a super duper router giving low through put.
It goes without saying hardwired through put is blistering !!!!!! In fact my nas box ( QNAP TS 209 ) has such a low processor it's unable to achieve more than 2.03 MB/s while downloading overnight from UseNet servers but when I put my usenet client ( SABnzbD ) onto a proper computer I achieved 11.04 MB/s ( thats a 12gb file in about 9 mins ) !!!!!!!! I can live with that :0)
Si
26-10-2010 10:38 AM
Isn't technology great? Nice usenet speed btw!
26-10-2010 10:54 AM
Homeplugs are fine for low bandwidth connections but you can't beat wire !!!!!
BTW I play MKV files at 1080p which are mostly are around 20gb and I never see any problems 🙂
Given everyone used cordless phones I think changing the phone points to be ethernet so very sensible
Si
26-10-2010 12:21 PM
26-10-2010 2:52 PM
In the end I disabled the wireless and used an old external access point which I never had any problems with. I think that privacy feature (WPS) makes it go screwy whether it's on or off.
I've tried Powerline homeplugs before. Not bad, but windows networking did not work well between pcs and NAS.
I've since taken the plunge and run Cat 5e wired sockets and never looked back. I wasted so much time fiddling with wireless and wireless repeaters.
26-10-2010 3:00 PM
Wired is the way to go and as long as you have wiring in your walls for phone sockets your not using then seamless 100mg networking can be added. There is no need to go gigabit in my option as streaming the heaviest biggest files won't be a problem over a 100mg network.
Si
26-10-2010 3:14 PM
I'm going to do some testing with IxChariot tonight on the powerline adaptors and see what speeds I'm getting from them and see if it improves being moved to a different socket. If not I'll look into running some Cat5 to the bedroom (it's directly above the lounge so should be straight forward) as it would be nice to be able to play everything upstairs and not double check the filesize and bitrate first.
Re: [FTTP] Wireless performance of Netgear WNR3500
26-10-2010 5:16 PM
26-10-2010 9:23 PM
Si
27-10-2010 8:58 AM
27-10-2010 9:04 AM
27-10-2010 2:56 PM
27-10-2010 3:00 PM
Si
- Full Fibre
