FTTP Trial
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: FTTP Trial
Re: FTTP Trial
23-05-2017 2:50 PM - edited 23-05-2017 3:24 PM
Well the fibre cable was run to the house a couple of weeks ago by some BT engineers who called unannounced and without and appointment - and now another one has just been and left again unannounced and without an appointment but hey, at least I was home and at least the modem (are they still called that?) is now fitted - unfortunately it does not seem to be operating
Engineer left saying that when the amber light display turns blue in about an hour I will be able to use it, but it's now been over a couple of hours at least since the guy left and it's still on amber so I guess a longer wait is in order.
Have advised the support team on existing ticket #147517753 but as I have not had a reply to my previous two questions I'm not anticipating they'll get back to me this time either but, you never know.
Left with no internet at all so I then had to plug in and fire up the old plusnet modem so at least I'm back on line again so small mercies and all that
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
Re: FTTP Trial
23-05-2017 3:06 PM
Hi, sounds like things are getting close. I've just checked the order and it's not closed off yet and we've been advised to check for an update on Thursday. Fingers crossed you're not waiting too much longer.
Re: FTTP Trial
23-05-2017 3:25 PM
Thanks Chris, fingers crossed and thumbs up eh?
Herman Melville
Re: FTTP Trial
23-05-2017 7:24 PM
@Minivanman wrote:
... and at least the modem (are they still called that?) is now fitted ...
It is called an Optical Network Terminal (ONT for short)
Re: FTTP Trial
23-05-2017 8:14 PM
Classic BT engineer tactic - tell customer to give it a couple of hours and run like hell
Re: FTTP Trial
23-05-2017 10:27 PM
Well to be I'm honest I did ask him how much salt I should take with that. Not sure if he was amused or not
Herman Melville
Re: FTTP Trial
24-05-2017 8:38 AM
Thanks for that, it did seem a bit of a misnomer but I suspect modem will be with us for some time yet
Herman Melville
Re: FTTP Trial
24-05-2017 12:06 PM
Although there are several ONT models supplied by BT so mine is probably different to yours, I've never seen any blue lights on mine so I'm guessing you are referring to a blue light on your router?
Perhaps your router has not been set up with your login details?
In case you're not aware the router has to be set up with a PPPoE connection using said PN login details.
A quick and easy way to test if your FTTP connection is actually 'live' is to set up a PPPoE connection on your computer and bypass the router completely, i.e. connect your computer NIC directly to LAN1 on the ONT with an Ethernet cable.
To set up said PPPoE connection, go to Windows Network and Sharing Centre, choose 'Setup a new connection or network' / 'Connect to the Internet' / 'Broadband (PPPoE)' then enter your credentials (not forgetting that your PN username is generally 'myaccountname@plusdsl.net')
Good luck!
Re: FTTP Trial
24-05-2017 12:47 PM - edited 24-05-2017 12:50 PM
Cheers @RobPN
Have now tried that but even though I have 'cable connected' to the new BTHub5-MKRQ it's still not seeing it so perhaps somewhere down the line it's not activated?
This is the one they left showing the amber light "which will go blue". More than a bit miffed that he left without making sure it was not working and with me not connected (had to reinstall the plusnet modem). Went to the site 192.168.1.254 suggested by plusnet chat to connect the new hub but that just takes me to the Technicolor Gateway.... which is obviously the wrong one!
Think maybe I'll have to get the BT guy back as I'd hate to lose my internet connection completely
PS. Plusnet should have sent me a new hub but the chat guy said to use the BT one supplied by the engineer as it was better?
Herman Melville
Re: FTTP Trial
24-05-2017 12:59 PM
That sounds like you've got both the Techicolor and the new BT hub connected to the LAN at the same time, that's not going to work. By default they will both have the same internal IP address 192.168.1.254.
Aah! the BT hub will definitely need configuring with your PlusNet username/password. Can you connect a Pc or Laptop directly to the BT hub ?
Re: FTTP Trial
24-05-2017 1:32 PM - edited 24-05-2017 1:35 PM
@Minivanman wrote:
Cheers @RobPN
Have you actually tried what I suggested, i.e. a direct PPPoE connection to the ONT? It sounds as if you may have confused connecting an Ethernet cable to the router with what I said, which was to not use the router at all, but connect the computer directly to the ONT via an Ethernet cable.
Edit: typos
Re: FTTP Trial
24-05-2017 3:30 PM
Confused? probably at my age
Anyways followed your advice and together with the plusnet help line who suggested I also plug in the PSTN line to the new router it now seems to be working. Just need to check the line speed now as it should be far higher.
Cheers.
Herman Melville
Re: FTTP Trial
24-05-2017 3:37 PM
We've got some work to do on that side of things, your account is still on an ADSL package, so your speeds will likely not be much higher than ADSL speeds
Bear with me on that one.
Sorry to see that wasn't sent. I've added one to your account and arranged for it to be sent out for you.
Re: FTTP Trial
24-05-2017 3:42 PM - edited 24-05-2017 3:44 PM
They suggested what!!! , it sounds like you've now got ADSL again, but via the new router.
To be fair, I suspect most of the CSC staff wouldn't have a clue about FTTP.
Do as RobPN suggests, connect your PC directly via a network cable to the ONT and set up a PPPoE connection directly on the PC. That way you'll prove whether the ONT is working or not and then we can proceed to try connecting the new router to the ONT
Re: FTTP Trial
24-05-2017 3:46 PM
It does seem like it @MisterW as my line speed is the same but the plusnet guy on the phone said "it needs to settle down". Am I being sold a pup? Methinks I am.
Herman Melville
