FTTP Trial Update - 23rd September
- Full Fibre
- Re: FTTP Trial Update - 23rd September
23-09-2010 3:33 PM
Shenley Lodge: PCP 95 area is declared C-RFS for 23rd Sept. PCP areas 74 and 75 will be C-RFS by 30th Sept
Cabinets 77 (Loughton) and 109 (Kents Hill) are now shown as complete with immediate C-RFS
Willen: PCP areas 44 and 69 is expected be declared C-RFS by 30th Sept
Woolstone PCP area 45 should also be declared C-RFS by 30th Sept
I am also pleased to provide advance information on working indicative target dates for C-RFS availability for the following
Monkstone Park – (PCP area 121) C-RFS by 13th October
Woughton on the Green (PCP area 70) C-RFS by 18th October
Bleak Hall (PCP8) C-RFS by 30th October
Monkstone (PCP area 112 and 11T) C-RFS by 3rd November
Plusnet Technology
23-09-2010 6:11 PM
Dave in your experience, how accurate do you think those dates for Monston Park are ?
Thanks for the update BTW
Si
24-09-2010 1:35 PM
Plusnet Technology
24-09-2010 3:49 PM
27-09-2010 10:56 AM
30-09-2010 3:38 PM
What will happen next: how will you be contacting budding triallists one the switch has been flicked?
Kind regards,
Bruce.
30-09-2010 3:48 PM
Plusnet Technology
11-10-2010 2:48 PM
How we looking for "monkey" park being enabled on the 13th ?
Assuming it does get switched on on Wednesday, whats the lead time for BT to perform an install ?
Si
11-10-2010 3:39 PM
This is the update hot off the press today:
Please note confirmation of the new cabinet C-RFS notification for this week.
I include advance information on working indicative target dates for C-RFS availability for the following
There's a couple of you on cab 121, I'll be sending invites out later today. Lead time is a minimum of about 10 days from the cab being enabled so you're probably looking at 23rd October as the earliest available date. Although for the 2 step install we can probably do the first appointment a little earlier. BT say it's best to leave a gap between the 1st and 2nd appointment in case the 1st over-runs.
Plusnet Technology
11-10-2010 4:11 PM
I've not been this excited for ages.
I'm a big usenet user ( as you might be able to tell from my usage stats ) so I should be able to give a very accurate through out/download speed as I have full speed downloads from my usenet servers.
Si
11-10-2010 6:20 PM
Plusnet Technology
11-10-2010 6:53 PM
Do I get a gold star for speed.
Si
14-10-2010 1:04 PM
Just replied in the other thread, should have checked here first. I'm also in Monkston Park, MK10 9PY. I don't suppose I'm on the same cab or you have any idea when mine will be ready? - I've not had an invite that I'm aware of...
14-10-2010 6:34 PM
Plusnet Technology
15-10-2010 7:24 AM
"Our test also indicates that your line currently supports a WBC Fibre To The Premises technology with an estimated Broadband downstream line speed of up to 100Mbps and upstream line speed of up to 30Mbps."
Speed tests though still show me having just 1.6Mbps downstream, an improvement over 6 months ago when it was just 0.92Mbps, but still not impressive.
What do I have to do to benefit from this fttp line? I move large photo files around so it would be great to have the improved bandwidth.
graeme@boomboom.f9.co.uk
- Full Fibre
